Here she is Tony. . .
eanmizell
Tomball(Houston), TX
I love the kit, but it rides a little rougher now. Would adding better shocks help? Any suggestions?
eanmizell
eanmizell
I know I've read all that, but it doesn't ride like shit, it's just a lil rough, I'm not bouncing around or anything.
soulsea
Bar
Yeah well a 23yo spritly young man calls the same thing 'a lil rough' that an old fart like me calls 'someone get me a masseuse and a percocet.' :)
Yeah the answer seems to be the free travel mod.
eanmizell
eanmizell
Lol, then that's what I'll do haha, free travel mod FTW!!
NORCAL SS
SUV SUSPENSION GURU
i forgot what kit you went with bud?
spindles in front and 3-4 inch adjustable springs in rear?
NORCAL SS
SUV SUSPENSION GURU
with spindles ride doenst change
in rear if your using no spacer and with the shock extenders in you should cut the bracket off the frame will help a lot.
NORCAL SS
SUV SUSPENSION GURU
rear looks pretty dropped. I would cut the brackets off anyway will ride better.
haehlSt0rm
WA
dope!!! it definately sets your ride off.. love it. and definately do free travel mod
NORCAL SS
SUV SUSPENSION GURU
lol sweet you were on a mission tonight lol.
If you need bumpstops just hollar i have the ones that you drill/tap hole and then they screw right into the frame.
works for your truck also
http://www.tbssowners.com/store/index.php?act=viewProd&productId=66
btw what does it measure both in front/rear from ground to fenderlip and also what tires on it?
looks like 34.25-34.5 in front and 35.25-35.5 rear
eanmizell
eanmizell
Your an amazing picture guesser wheel height guy haha, 34.5" front and 35.5" in rear, by the way I didn't cut them all the way off, I left like an inch or half an inch cause just incase I load a lil in the rear I don't want metal on metal
NORCAL SS
SUV SUSPENSION GURU
OH YOU just cut bumpstop. I thought you took ENTIRE bracket off the frame. If you do that you get 3 inches more axle movement.
btw you can cut the spacer in half if you wanted do drop rear end 1/2 inch
eanmizell
eanmizell
Sweet appreciate all the help and informative information haha and with the prompt shipping and quality products, thanks again. By the way you can use those pics if you want and if you want some different angles let me know :)
NORCAL SS
SUV SUSPENSION GURU
right on thanks. Ill keep it in this section and forward people to it.
305 35 24?
JamesinAbilene
