View Full Version : Oil pan!
98chubby
10-31-2011, 10:24 PM
Can anyone tell me if i have to remove anything else besides the oil pan to remove the gasket? My truck is lifted so at least i don't have to jack it up. Any help would be greatly appreciated.
SunlitComet
11-01-2011, 03:54 AM
2wd or 4wd?
---------- Post added at 12:54 AM ---------- Previous post was at 12:48 AM ----------
depending on you answer it will go from :Frustrated: job to a :wtf::pp: kinda a job.
retorq
11-01-2011, 09:50 AM
Lol
custom97
11-01-2011, 11:41 AM
Engine or Tranny?
98chubby
11-01-2011, 01:49 PM
It's for the oil pan, 4wd 5.7 v8 for the engine
dsltrc
11-01-2011, 02:17 PM
i know when i had to drop my oil pan i had to remove front driveshaft and unbolt top diff bolt and passenger side axle bolts then rotate front axle forward out of the way...
SunlitComet
11-01-2011, 06:30 PM
Removal of Y-pipe and front driveshaft most likely needed.
Oil Pan Replacement REMOVAL PROCEDURE
http://www.alldatadiy.com/alldata/AFI%7EV28803569%7EC33210%7ER0%7EOB0%7EP3R0H%7EN/0/70910848/78153753/78154197/78154199/34853741/100411974/34853743/34872056/34855639/113001847/81940946/81940947
Remove the oil level indicator tube. Refer to Oil Level Indicator and Tube Replacement.
Raise the vehicle.
Remove the engine oil and the engine oil filter (http://www.alldatadiy.com/alldata/AFI%7EV28803569%7EC33210%7ER0%7EOD%7EN/0/70910848/78153753/78154197/78154199/34853741/100411974/34853743/34872055). Refer to Engine Oil and Oil Filter Replacement.
Remove the oil filter adapter (http://www.alldatadiy.com/alldata/AFI%7EV28803569%7EC33210%7ER0%7EOD%7EN/0/70910848/78153753/78154197/78154199/34853741/100411974/34853743/56492446). Refer to Oil Filter Adapter and Valve Assembly Replacement.
Remove the starter. Refer to Starter Motor Replacement.
Remove the flywheel inspection cover.
Remove the engine mount (http://www.alldatadiy.com/alldata/AFI%7EV28803569%7EC33210%7ER0%7EOD%7EN/0/70910848/78153753/78154197/78154199/34853741/100411974/34853743/34872052) through bolts. Refer to Engine Mount Replacement (2WD).
Raise and support the engine.
Remove the oil pan.
Note the location of any studs to assist reassembly.
Clean all the sealing surfaces. Refer to Oil Pan Clean and Inspect.
Remove the engine oil pan and the gasket.
INSTALLATION PROCEDURE
http://www.alldatadiy.com/alldata/AFI%7EV28803569%7EC33210%7ER0%7EOB0%7EP3R0H%7EN/0/70910848/78153753/78154197/78154199/34853741/100411974/34853743/34872056/34855639/113001847/81940946/81940948
Install the engine oil pan and a NEW oil pan gasket (http://www.alldatadiy.com/alldata/AFI%7EV28803569%7EC33210%7ER0%7EOD%7EN/0/70910848/78153753/78154197/78154199/34853741/100411974/34853743/34872058). Refer to Oil Pan Installation.
Lower the engine onto the engine mounts.
Install the engine mount (http://www.alldatadiy.com/alldata/AFI%7EV28803569%7EC33210%7ER0%7EOD%7EN/0/70910848/78153753/78154197/78154199/34853741/100411974/34853743/34872052) through-bolts. Refer to Engine Mount Replacement (2WD).
Install the starter. Refer to Starter Motor Replacement.
Install the flywheel inspection cover.
Install the oil filter adapter (http://www.alldatadiy.com/alldata/AFI%7EV28803569%7EC33210%7ER0%7EOD%7EN/0/70910848/78153753/78154197/78154199/34853741/100411974/34853743/56492446). Refer to Oil Filter Adapter and Valve Assembly Replacement.
Install the engine oil filter (http://www.alldatadiy.com/alldata/AFI%7EV28803569%7EC33210%7ER0%7EOD%7EN/0/70910848/78153753/78154197/78154199/34853741/100411974/34853743/34872055) and the engine oil. Refer to Engine Oil and Oil Filter Replacement
Lower the vehicle.
Install the oil level indicator tube. Refer to Oil Level Indicator and Tube Replacement.
98chubby
11-01-2011, 09:50 PM
It was a pain in the ass!!!!!! OMG!!!!! Sorry for yelling but damn I have a 3 inch body lift as well and i can only imagine how hard it is for people who don't have body lifts. All i had to do was move the oil filter and adapter also a bar that runs from the tranny to the body. But thanks guys for the info it was most appreciated. I'm still thinking about it........geezzzzus!
vBulletin® v3.8.7, Copyright ©2000-2012, vBulletin Solutions, Inc.
