View Full Version : Rattling windows
jacksoncove
10-13-2011, 04:21 PM
Hi All I have a 02 Yukon XL its a great vehicle, but there is a annoying problem. When the driver and passenger side windows are down they rattle when you hit a bump in the road. When they are past half way up or all the way up they are fine. What is the fix for this? Thank you in advanced
GeneralNoobzor
10-13-2011, 05:45 PM
Why don't you find out yourself? Remove the door panel and then roll down the window like you said and then just gently bang on the door and see where the rattle is? :)
jacksoncove
10-14-2011, 07:51 AM
I was just wondering if any one incountered this, and what the fix might be so I could save some time
It's a known issue with our trucks. You'll just have to pull the door panel and see where it's coming from.
Divino92
10-14-2011, 09:47 AM
I have the same problem. I am not sure what it is, but this weekend I planned on pulling off my door panels and using some rust inhibitor inside of them. If i figure it out I will let you know .:)
jacksoncove
10-14-2011, 10:10 AM
Thank guys, I have to install new side view mirrors this weekend, so I will do the same and pull the door panels also and report back
Divino92
10-16-2011, 05:58 PM
I didnt get the chance to do much this weekend, but hopefully in the next couple of weeks I can
jacksoncove
10-17-2011, 02:28 PM
I did find out what was the cause, it was the one of the window regulator 10 mm mounting bolts that came loose
GeneralNoobzor
11-05-2011, 01:49 PM
Thanks for the info! :)
jacksoncove
11-28-2011, 11:07 AM
your welcome
rippinitup
11-29-2011, 01:40 AM
i have the same problem. gonna have to open it up and look for that bolt!
vBulletin® v3.8.7, Copyright ©2000-2012, vBulletin Solutions, Inc.
