bolt torque sequence??
Dahoe
Houston
like title says i need to know the bolt pattern and torque specs for the heads on my hoe, if anybody can help me find it please post the link id appreciate it =)
greenhornet
Ontario,Canada
YLINDER HEAD BOLT
NOTE:
Do not reuse the cylinder head bolts. Install NEW cylinder head bolts during assembly.
Do not use any type sealant on the cylinder head gasket (unless specified).
Tighten the M11 cylinder head bolts a first pass in sequence to 30 N.m (22 lb ft).
Tighten the M11 cylinder head bolts a second pass in sequence to 90 degrees using the J 36660-A.
Tighten the M11 cylinder head bolts (1,2,3,4,5,6,7,8) to 90 degrees and the M11 cylinder head bolts (9 and 10) to 50 degrees a final pass in sequence to using the J 36660-A.
Tighten the M8 cylinder head bolts (11,12,13,14,15) to 30 N.m (22 lb ft) . Begin with the center bolt (11) and alternating side-to-side, work outward tightening all of the bolts.http://www.alldatadiy.com/alldata/A...4854590/34855099/127930089/140766725/84962707
WITCH1975
