PDA
View Full Version : Fault Code P0719
navi243
09-10-2011, 09:03 PM
Check engine light just came on and my fault code is p0719.
Has anyone resolved this issue? I was told it is the brake switch. But want to be certain that the guys at the parts store know what they are talking about.
If it is the brake switch where is it located?
SunlitComet
09-10-2011, 10:26 PM
Above the brake pedal and costs about $15.
navi243
09-10-2011, 10:56 PM
thanks for all the replies, your on top of everything
is it difficult at all to remove, and should this part fix my problem?
SunlitComet
09-10-2011, 11:15 PM
Service and Repair REMOVAL PROCEDURE
http://www.alldatadiy.com/alldata/AFI%7EV28054220%7EC33210%7ER0%7EOB0%7EP3R0H%7EN/0/70910848/78153753/78154197/78154199/34853741/34867926/101367307/34850045/81079696/81079697
For information on stoplamp circuit diagnosis, refer to Lighting and Horns.
CAUTION: Refer to Battery Disconnect Caution in Service Precautions.
Disconnect the negative battery cable.
Disable the SIR.
Remove the pushrod retainer from the brake pedal pin. Use snap ring pliers.
Unsnap the stoplamp switch from the pushrod.
Disconnect the electrical connector from the stoplamp switch.
INSTALLATION PROCEDURE
http://www.alldatadiy.com/alldata/AFI%7EV28054220%7EC33210%7ER0%7EOB0%7EP3R0H%7EN/0/70910848/78153753/78154197/78154199/34853741/34867926/101367307/34850045/81079696/81079698
Connect the electrical connector to the stoplamp switch.
Snap the stoplamp switch onto the pushrod.
Install a new pushrod retainer on the brake pedal pin. Use an 11 mm (7/16 inch) socket in order to push a new clip onto the pin.
Connect the negative battery cable.
Enable the SIR.
navi243
09-10-2011, 11:28 PM
you are the man
SunlitComet
09-11-2011, 07:56 PM
I get that a lot. I don't understand why?
navi243
09-11-2011, 08:27 PM
i tried to get it done today but it is really tight up where the switch is and by the time i got outside it was already getting bit dark
any suggestions on getting htis tiny thing out of there with all the other cluter that is around it? i dont even thing i can get the snap ring pliers in there
SunlitComet
09-11-2011, 08:40 PM
wait til it is brighter. Perhaps get a mirror to prop up the and some angled pliers. I have heard once or twice people just prying of the old with a screw driver since a new switch and snap ring were going on. Perhaps you might want to get postal with it.:)
navi243
09-11-2011, 08:51 PM
unfortunatley mine didnt come with a new snap ring so i prob need ot be careful
