View Full Version : how to diagnose a bad idler/tensioner pulley?
04ctd
09-06-2011, 09:35 PM
got a used Tahoe, 2007, almost 100k miles.
it has a random intermittent pulley noise.
sounds just like the Trailblazers did, that they did the recall on the pulley for.
problem is, it has 2 fan belts, so it has 2 tensioners, and 1 idler on the big belt
and it only does it ever so often, AC is not a factor.
what's best way to find the bad one?
pull the belts and feel for wobble?
domin8
09-07-2011, 04:50 PM
How do the belts look? Are the tensioners tight against the belts?
ezdaar
09-07-2011, 06:04 PM
engine off, remove belt from tensioner. Grab it and try to wiggle it towards radiator.. does it move? try the tensioner arm and pulley. if any slop. its bad...
taylorjm
09-07-2011, 08:53 PM
Someone told me once that when it's making noise, take a piece of pvc pipe and put it down by the pulley in question, and the other end to your ear (try to not touch the pipe to anything that's moving). You should be able to isolate the problem.
04ctd
09-08-2011, 08:01 AM
yes, look good. previous owner looked to be a "jiffy lube" type of person who did the cheap maintenance.
that sounds, i had heard the trick on putting a long screwdriver on a valve cover to find a noise, the pipe trick sounds neat.
it never does though...unless i am late, in dress clothes, and the wife is already screaming LETS GO
tks Ez, gonna pop the belts off & wiggle test them all.
vBulletin® v3.8.7, Copyright ©2000-2012, vBulletin Solutions, Inc.
