Knocking/ Chattering at high rpms
19964x4HOE
Waterloo, IA
hello,
Id first like to start off with saying i am new here and this is my first thread. BUt i have been a member on other auto forums so this isnt my first time on a forum. I jsut purchased a 1996 Chevy Tahoe about 3 weeks ago. It is 4WD, 2 door bone stock. And i just noticed that there is a slightly loud knocking/chattering noise coming form the engine bay only at 4k rpms and above it seems like. I have seafomed the engine and tried some oil treatment stuff and that didnt do anything. Anyone have any ideas? Thank you very much
Bryant
---------- Post added at 04:14 PM ---------- Previous post was at 04:09 PM ----------
btw its the 5.7 with 4L60 tranny
Gzes
the drifting 2dr
Wichita tx
When I got my truck out of my back yard and decided to fix it up I had a problem. It worked and ran good but the oil pressure was always low. I would rev it up and the pressure would go up. So I didn't use I as a daily driver but then it started to know very little and I had to get the complete overhaul because the crankshaft was extremely worn. Migh be your problem also. By the way it's a 2 door hoe also look at my avatar. It only cost me $1400 to fix so...
SunlitComet
OBS Jedi-Do Good
unknown at this time.
hello,
Bryant
:welcome:
If you can get a video or audio file posted of it It will help aot to diagnose it.
retorq
Kingman AZ
I can count the number of times in a typical week that my truck sees 4K or above ...
19964x4HOE
Waterloo, IA
ok i will try to get a video of it here in just a little bit...
And i dont believe my truck sat for awhile before i got it. I have checked all the obvious things already. The truck is holding perfect oil psi. Its not throwing any codes other than a code for each Pre-Cat o2 sensor... but i doubt thats making it knock..
---------- Post added at 06:56 PM ---------- Previous post was at 06:53 PM ----------
im not saying i floor it everywhere just this was the first time i actually floored it bcuz my buddy in his 94 Full size blazer wanted to race :p lmao. And now since i heard the sound its always bugging me..
SunlitComet
OBS Jedi-Do Good
The noise seems to be tied the the vibration high point of engine. Seriously that sounds like a loose or broken heat shield on the catalytic converters or other piece of metal flapping around down there like shields on exhaust manifold. Not surprising giving the exhaust one of your truck. The fact that it shows and quickly disappears in a specific range means something is buzzing around.
SunlitComet
OBS Jedi-Do Good
lower bell housing inspection cover on tranny? protective drive-train shields. maybe even broken substrate in the cat converters?
SunlitComet
OBS Jedi-Do Good
Only other thing that comes to mine at the moment is a loose valve adjustment somewhere but that is a long shot. How about any other brackets under the hood?
19964x4HOE
Waterloo, IA
I sure hope its not a valve adjustment lol even though its not that bard. Tomorkw when I get off work I will check everything over one more time.
Gzes
the drifting 2dr
Wichita tx
You should check it out before it is something important and ***** up the inside and you have to get a new block or an overhaul. I have to see the sound clip but could it be the lifters?
19964x4HOE
Waterloo, IA
that was my 2nd guess for something internal gzes... Lifters or valve adjustment... Its not a horrible knock. Its more like a chatter... but idk exactly the best way to diagnose th esound more clear besides using a screwdriver lol
Gzes
the drifting 2dr
Wichita tx
Well my damn iPhone won't let me see the clip so I can't say what it could be but I guess it's the lifters. I had an explored and it's litters were bad and it sounded like you described but it shouldn't cause any real damage just to the worn lifters but I sold it before I got to them so I didn't have to worry about it. It happens alot when you just hop in the car and go but you have to warm up the car before you leave. Dud the previous owner just hop in in the morning and go wherever?
Gzes
the drifting 2dr
Wichita tx
Ok but check the lifters because thats what I think it is and yea it's ******* annoying but that's what the radio is for on high lol:)
JamesinAbilene
