View Full Version : Fitting 305/50/R20 .!.
TahoeLT
07-31-2009, 01:11 PM
hello
I'm happy to register in the forum :Handshake:
my 09tahoe with stock 17 wheels
now i heve OEM 20×8.5 wheels
the OEM tire size is 275/55/20
I thinking to fitting 305/50/R20 :hands:
but without any lifting ?
is it passable or not?
and my important Q is there any problem with front tire Width when i turn max left or right ?
thanks and best regards...
tast101
07-31-2009, 02:00 PM
Welcome to the forum. One of the wheel guys will chime in shortly
Conor
07-31-2009, 02:44 PM
I am pretty sure a 305/50 R20 will not fit. And if it did, I don't think you would like the way they would look stuffed in there. The closest size that will fit for sure is a
295/50 R20. That size would be your best bet in my opinion.
TahoeLT
07-31-2009, 05:27 PM
Thanks Dear tast101 :)
Dear Conor
Thanks ... I.ll think about 295
Nat2tc
08-01-2009, 02:57 PM
Hi all, 1st time posting.
I just put on 305x55 R20 on factory 20x8.5 wheels with no lift. Tires rubbed a little in the front when turning tight. Rubbed a little in the back when rear is compressed about 2 inches (going over big bumps!). I installed a ReadyLift 1.5 inch lift in the front and 1 inch lift in the rear. No more tires rubbing. Tires look great. Do not noticeably stick out the fender well. I'll post pix as soon as I figure out how!!!
Nat
JennaBear
08-01-2009, 03:01 PM
I have 305/50/20s on mine. There was slight rubbing when at full crank, but a simple zip tying and you are good to go.
http://www.blackbearperformance.com/Tahoe/.%5C7-10-05/9.jpg
http://www.blackbearperformance.com/Tahoe/.%5C6-19-2005/side_low.jpg
UofMZ71
08-01-2009, 03:31 PM
i have 285/65/18 which is just slightly larger than 305/50/20, but slightly smaller than 305/55/20, with a 2.5" leveling kit and they rub on the right side at full turn.
I think you might have some rubbing issues if you go to that size...
JennaBear
08-01-2009, 03:32 PM
I should have preempted my post with the fact that backspacing/offset are a huge factor in this.
vBulletin® v3.8.7, Copyright ©2000-2012, vBulletin Solutions, Inc.
