View Full Version : Blown Bose speaker
neloms
05-05-2009, 02:00 AM
I've got the Bose stock system in my 2005 rig and the front driver door speaker is blown. Is this an easy swap or am I going to have to cut out the speaker, splice wires and use self tapping screws to install a new one? I'd change both front speakers at the same time...
Timmy
05-05-2009, 02:05 AM
you should either replace all the speakers or go back with bose. it'll prevent a lot of headaches...
JKmotorsports
05-05-2009, 02:51 AM
If you do replace them with aftermarkets, you'll have to mount them with self-tappers. The "true" speaker size is 6 3/4", but any 6 1/2" will do. Some companies make the oversized GM 6 3/4" sizes though. For the wiring, you can buy speaker harness adapters that will plug into the stock speaker harness. You can get these at your local stereo shop or Best Buy.
One more thing, the Bose speakers are two ohm, whereas most aftermarkets are 4ohm, so you may notice a slight difference in output.
Timmy
05-05-2009, 02:53 AM
http://www.gmfullsize.com/forum/showthread.php?t=153023
JKmotorsports
05-05-2009, 03:18 AM
http://www.gmfullsize.com/forum/showthread.php?t=153023 (http://www.gmfullsize.com/forum/showthread.php?t=153023)
The guy was doing something wrong. I install countless number of speakers in 03+ GM trucks with no problems. The amplifier's channels aren't tied into any of the DDM's functions. And what the Best Buy guy said is bogus too. You do not have to rip out all the Bose or On-star crap just to install new speakers.
Timmy
05-05-2009, 03:20 AM
just posting that up. idk what it was. i don't have bose. haha
JKmotorsports
05-05-2009, 03:23 AM
Yea, that's kinda weird. The only thing I can think of is that he may have been screwing into a harness behind the panel when he was mounting his aftermarkets.
Timmy
05-05-2009, 03:25 AM
that or he might have had something hooked up backwards.
fatnlowtahoe504
05-05-2009, 03:44 AM
X2, if you find a bose one off ebay or something, it just pops in and out and its a plug for the wiring, but i would keep it bose until your ready to get a whole good system of door speakers and amp
Timmy
05-05-2009, 03:46 AM
could not agree more
blueflamed03
05-05-2009, 05:41 PM
and you can add a seperate subwoofer to the factory Bose setup as well...(contrary to what is all over forums)
neloms
05-05-2009, 06:38 PM
Have you seen a DIY thread on that install? I'd love to do that as well. Thanks for all the input, guys!
Tahoe03mm
05-14-2009, 02:18 PM
I had the Bose, I just bought an add-an-amp harness and tapped into existing sub leads and installed my own turn on switch(you could easily tie into something that uses accesory turn-on as well I'm sure).
Rollin Thunder
05-14-2009, 03:08 PM
I had bose and put polk speakers in place of the bose with stock everything else. Worked fine. Sound even better now with a complete system.
tom q
05-22-2009, 01:50 PM
I'm changing my front speakers right now... I'll let you know what happens
SFBerto415
05-22-2009, 09:16 PM
How do I add a seperate sub to my Stock Bose System? Where should I look?
neloms
05-27-2009, 09:36 PM
Thanks for the tips! I found some Infinity Reference speakers that are two ohm, I might buy four of those and do all the speakers at once...
vBulletin® v3.8.7, Copyright ©2000-2012, vBulletin Solutions, Inc.
