View Full Version : Ok got my amp back from memphis
texaschevyryder
07-20-2009, 07:43 PM
New motherboard installed she beats great one lil problem da setup i have i have the cap grounded under the back seats where the amp is and i hear the acceleration of my truck thru da speakers and its annoying.......any other sugesstions for ground spot
Ninety5PoloZ
07-20-2009, 07:47 PM
It also might be where the power wire is run or if the other wires are run near the power wire.
The ground should be ok, but I don't know for sure
texaschevyryder
07-20-2009, 07:51 PM
it also might be where the power wire is run or if the other wires are run near the power wire.
The ground should be ok, but i don't know for sure
well the ground and the power are running off of the cap if that makes any sense to you
TahoeGoBoom
07-20-2009, 10:39 PM
is it your woofer amp? cuz then it shouldnt really matter..
i'd run a separate ground if i were you. I wouldnt run it directly off the cap. you'll get better current if it has its own ground.
DJTricky
07-20-2009, 10:59 PM
if i were you i would drill a hole through the floor. And ground to the frame. Like me haha
foreverfalcon40
07-21-2009, 12:31 AM
I don't suggest anyone drilling holes into there body. Just another hole for elements to get in.
I capped mine in the rear seats. Gte out the sand paper make sure theres no paint its metal to metal. Like the other guy said...noise is from the positive wire.
doggworld1233
07-21-2009, 08:17 AM
is it a bass amp??? they should not have noise??
do you have a pioneer hu? if so that is prob your problem
blueflamed03
07-21-2009, 09:44 AM
where is the front amp if any, and look at ground, and placement of RCA's.
BigRed96
07-22-2009, 06:25 PM
sounds like your running your power wire next to the rcas IMO...
texaschevyryder
08-03-2009, 03:46 PM
i just backed the amp down not as noticable now
TahoeGoBoom
08-03-2009, 06:09 PM
yeah, if you dont amplify it as much it wont be as loud... still wouldnt fix your problem tho...
texaschevyryder
08-04-2009, 08:18 AM
is it a bass amp??? They should not have noise??
Do you have a pioneer hu? If so that is prob your problem
well when i had my kenwood amp i never had dat problema and wires are run da same for the most part
doggworld1233
08-04-2009, 01:29 PM
so you have a pionner hu?? is it a bass amp or for mid/highs?
texaschevyryder
08-04-2009, 07:48 PM
yea i have a pioneer head unit its a bass amp
TahoeGoBoom
08-05-2009, 02:19 PM
the pioneer is bad. change the HU and it'll be fixed.
Ninety5PoloZ
08-05-2009, 03:08 PM
^^Agreed, either that or the RCAs are too close to the power wire.
Its probably something simple, it always seems to be like that. Also where is the power wire run through the engine compartment?
doggworld1233
08-06-2009, 08:59 PM
try this... take the radio out and use the ground from the radio to the rca shield.. if that gets rid of the noise then the pico(sp) fuse is bad on the radio...
http://i72.photobucket.com/albums/i193/Scottpatuofm/My%20Car%20Audio%20Portfolio/Pioneer%20RCA%20tutorial/IMG_1066.jpg
http://i72.photobucket.com/albums/i193/Scottpatuofm/My%20Car%20Audio%20Portfolio/Pioneer%20RCA%20tutorial/IMG_1067.jpg
http://i72.photobucket.com/albums/i193/Scottpatuofm/My%20Car%20Audio%20Portfolio/Pioneer%20RCA%20tutorial/IMG_1069.jpg
vBulletin® v3.8.7, Copyright ©2000-2012, vBulletin Solutions, Inc.
