PDA
View Full Version : power sterring line question
ramfan98
05-07-2011, 09:15 PM
i have a 96 yukon that has a leaky power steering line. my question is which one is pressure and which one is the return? thanks!.
SunlitComet
05-08-2011, 04:02 AM
the pressure should be a line with metal with a middle rubber section with a 180 bend on one end. the return line would be all rubber.
foreverfalcon40
05-08-2011, 10:30 PM
If the line is leaking, you are going to have to pull the pump b/c they are conveniently located right behing it which is a bitch to do.
Might as well replace the pump while your are at it. You are going to have to pull the pump. Feel like splurging fork an extra $40 to delete the EVO steering sensor.
I have re-done my pump 3 x. Need help I will walk you threw it.
You will need a pulley puller which you can get at local advanced auto thru their loaner tool program.
GL ff40
