PDA
View Full Version : gm preformance intake...
Rollin Thunder
07-14-2009, 11:31 PM
is this as good an AEM or K&N????
http://cgi.ebay.com/ebaymotors/GM-PERFORMANCE-PARTS-COLD-AIR-INTAKE-GMT-900_W0QQcmdZViewItemQQ_trkparmsZ65Q3a16Q7c39Q3a1QQ _trksidZp4506Q2ec0Q2em245QQhashZitem4147532ac4QQit emZ280369507012QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5 fAccessoriesQQsalenotsupported
Modded
07-15-2009, 12:13 AM
Yeah its just as good, but RT you should not be buying a used intake!?
Rollin Thunder
07-15-2009, 02:28 AM
y not
Modded
07-15-2009, 06:12 AM
Because you can get a ne and most likely better one from aftermarket......Airaid, Afe, Green, K&N, Injen, True Flow, S&B, Volant and many more all make some good ones.
I want to order one too but deciding is hard, do know it has to be a dry filter as the oiled ones involve alot of BS!
Also I don't want it to have a cover as I want it loud and notciable, I have narrowed it down to mainly aFe as its is affordable and good, check it out!
73shark
08-30-2009, 11:42 PM
The GM one is pretty loud w/ the lid on.
Without a lid, wouldn't you just be sucking hot underhood air in?
Modded
08-31-2009, 12:37 AM
Yeah w/o a lid CAIs do just suck in alot of hot engine air, that is unless it has the sealing design that isolates it from engine air when closed like Airraid uses.
73shark
09-01-2009, 12:05 AM
Does it seal to the underneath side of the hood then?
Modded
09-01-2009, 01:41 AM
Yeah it does, AfE intakes do also.
If you look at the pic of them installed you will see how it can do that with the top liner it has.
NoChrome
09-01-2009, 04:12 PM
well at least its legit... 175 is a bit steep for a used intake.
http://www.gmaccessorieszone.com/Chevrolet/2009/Tahoe/Performance%20Air%20Intake/?src=chevrolet&tx_gmshopb2b_pi1[type]=gm
