My Black Bear Story
ghoster
Baltimore
My Tahoe is still very new. I knew the day I drove it off the lot that it needed a few changes in the way it ran to be perfect. I contacted Black Bear, and purchase the Autocal. It was sent to me with all the instructions I needed to get started. I did all the logging and e-mailed everything in as per the instructions.
Yesterday was a nasty rainy day and I had to run a number of errands. I pulled up to a light waiting to make a left hand turn. I was waiting for any break in the traffic that I could squeeze in to (this was on a 4 lane road in Baltimore at lunch time). I saw my opportunity to get across coming, so I let off the brakes and was rolling forward, as the gap opened I put the pedal down about 3/4 of the way to the floor. Then I waited. And waited. And waited some more, (maybe a slight exaggeration) then the truck lurched into the gap and across the intersection. The delay between command and execution was staggering! I made it through, but it wasn't fun.
I tell that story so that I can now say this, the hesitation/delay, is GONE. I don't have any idea what they do to fix it, but it works. The Tahoe responds the way I expect it to now. I spent the last hour driving around testing the response time, and I am impressed. This is how GM should have made these things to start with. I didn't ask for a major performance tune or a mpg tune or anything very specific, I just asked Black Bear to make it better, and they did.
soulsea
Bar
Hey ghoster, I'm glad you like your tune ... but I can't help but think it may be masking something more important going on with your truck. There simply shouldn't be that much of a delay in response time when one hits the pedal that hard, especially for a brand new truck. If there was something wrong it might have been a good idea to get it looked at before the tune ... I don't know if these tunes negate the warranty should the issue rise again. :think:
Anyhoot, I don't meen to be a downer ... hopefully it will all be good. :waytogo:
ghoster
ghoster
Baltimore
I know pretty much what it was, it was the 6 speed. When I started rolling with 0 throttle it decided to shift to 2nd. Then I needed acceleration and it was still stuck trying to decide which gear it needed. Once its in the right gear it moved pretty well, it just seemed to take its time deciding to actually move! Either way its gone now. If I had kept my foot on the brake and up to the point of pressing the gas, it would have worked just fine.
soulsea
Bar
I understand now ... sheesh what kind of tune do they set at the factory on these things that it slips into 2nd gear from idle? :whymewhyme:
Congrats on the tune. :waytogo:
ghoster
ghoster
Baltimore
My guess is they are shooting for the best mpg's possible. And in reality, if you are pulling away slowly, 2nd gear has more than enough torque. Maybe this is just the growing pains of the 6 speed tranny?
My last 6 speed didn't have this problem..... but thats an apples to oranges kind of story.
nice and thanks for the feedback!!! I'm looking forward to the day I can do this mod! :waytogo:
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
did you do the tow/sport mode? Im still amazed how much kick there is between shifts that can be felt on a 7000 pound truck
ghoster
ghoster
Baltimore
They can't do that with the 6 speed. I don't really need it, but I can just flash in the performance tune if I need it.
Do you notice a pretty big difference on acceleration for like getting on the highway and getting up to highway speeds pretty quickly?
ghoster
ghoster
Baltimore
What I notice the most is reaction time. The truck doesn't hesitate at all. It also doesn't downshift as much under very light throttle. From a standstill the old butt dyno tells me its quicker. It seemed to pull harder when I was getting on the highway. Its perfect for me. I am running the 87 octanes tune right now. Thats what I will use on my long trips. At home I usually use Shell 93 octane. I will load up that tune later today and see if I can tell the difference.
Oh so you actually got two different tunes then? That is pretty awesome!
ghoster
ghoster
Baltimore
2 tunes for the different octanes, yes. I didn't opt for an all out performance tune so far. I want to get more miles on it before I do that to it!!
:waytogo: cool! and it's pretty easy to flash between set ups, I guess? This is all very intriguing to me as I look to get my tune by the end of the year I hope....
TahoeTX
Austin, TX
My 2009 Tahoe does this same thing and it's soooooo annoying! I'm positive it's because of the 6 speed transmission. It wants to stay in a higher gear at the wrong times. I can't wait for a tune. It makes you wonder how much GM tested these trucks in actual driving conditions.
ghoster
ghoster
Baltimore
Its very easy! You use your computer to flash the tune you want to use to the Autocal, then flash the tune from the Autocal to the truck. Pretty simple. It took me longer to figure out how to get the tune to the Autocal than it did to flash the tune to the truck. The instructions are pretty good, but lots of people that can help you if you need it. I like the option of being able to contact Black Bear and get another tune if I want it for the price of the tune only. It makes it simple! Right now I have no mods at all. In a few years I am likely to put on an exhaust and intake, maybe a few other things. It will be pretty easy to have Black Bear adjust my tune accordingly.
ghoster
ghoster
Baltimore
i got 6 tunes i can choose from. Stock ECM and Stock TCM, Sport and tow tcm, and a 87 and 93 tune
Well yes, but I already had the stock and tow tunes.:laughing1:
Now I have the 87 and 91 tunes. Do the separate tables for e85 count as another tune?
Sumo has got a wide variety :eek:
sumo
rhode island
you have a e85 tune? Justin told me i can just run e85 on the 87 tune no probs
JamesinAbilene
