http://www.sunlitcomet.com/pdf/auto...-Chevy-Tahoe-4WD-V8-350-4L60E-PCM-Diagram.pdf
http://www.sunlitcomet.com/pdf/automotive/tahoe/92-95/1995-Chevy-Tahoe-IAC-Testing.pdf
grounds:
G100 RH front of engine
G101 RH inner fender, near battery
G101 Sheet metal at RH front wheelhouse
G102 (VIN N) RH front of engine block, near damper pulley
G102 (VIN Z, H, K) LH front of intake manifold
G103 (Gasoline) Top front center of engine (gas)
G103 (VIN H, K) LH front of engine near thermostat housing
G103 (VIN N) LH front of engine near thermostat housing
G103 (VIN Z) LH front of engine near thermostat housing
G104 (VIN H, K) LH front of intake manifold
G104 (VIN N) LH front of engine near thermostat housing
G104 (VIN Z) RH top of cylinder head, near center
G105 (VIN Z H, K) RH front wheelhouse
G106 On intake manifold
G112 RH front of engine compartment, below underhood reel lamp
G113 On radiator support, near LH Headlamp
G150 On thermostat housing
G200 Behind LH side of I/P, below fuse block
G201 Behind LH side of I/P, below fuse block
G202 I/P harness, 15 cm from data link connector
G400 (Suburban) At RH C-pillar
G400 (Utility) At RH C-pillar
G400 RH "B" pillar
G401 Rear of LH framerail, behind bumper
G403 LH trailer hitch support
G404 On # 1 roof bow
G405 On # 1 roof bow
