View Full Version : lifted wheel size?
pukindog
07-06-2009, 01:28 AM
im looking to get a skyjacker 2-2.5" suspensioin lift.
what is an ideal wheel/tire size?
rim size
rim width
offset
backspace
etc.
i want them to look good and fit the truck. i obviously dont want the tires to be completely inside the wheel well but i dont want it sticking all the way out.
im just looking for different opinions. pics would be great.
thanks guys
99COOP
07-06-2009, 02:42 AM
Wrong section. but just run stock rims or stock specs imo. Slap a 285 tire on there and done. if u wanna stick out then run 4.5
pukindog
07-06-2009, 04:50 PM
toward the top of this page it says...
"Exterior Tires, Wheels, Paint, anything on the outside."
bowtiefreak
07-07-2009, 08:19 AM
What size wheels do you want? is it a 4x4? Do you want big wheels and low profile tires or a 16 or 17 with some real tires? All this plays a factor.
4.5" back spacing is good. sticks the wheels out just a bit....more so the wider the wheel.
pukindog
07-07-2009, 04:36 PM
I WANT REAL TIRES!!! i hate when people put low pro mudders on their trucks, that is so stupid.
and yes its 4x4
i was thinking 17"x10" wheels +/- unless i should i should go smaller. does offset matter?
99COOP
07-07-2009, 05:39 PM
I figured if your lifting it even though its a wheel question put it in the suspension section, either way dont matter. and 10's are a bit much for what tire size you would be using 11.5 or 12.5 ? go with a 17 like you said, you will be happier in the long run.
bowtiefreak
07-20-2009, 06:59 PM
run a 16x8 4.5" back spacing or a 17x8 or 17x9 all with 4.5 back spacing. They will all look good. get a nice 285 or even a 305 tire....lots of choices out there. And rule #1: pictures!
992door
07-21-2009, 10:19 PM
I am running a 17x9 on mine with 4.5" backspacing and a 285 I think that is a good combo
vBulletin® v3.8.7, Copyright ©2000-2012, vBulletin Solutions, Inc.
