Oil Pan, Differential & Transer Case LEAKS!
Devious02
Denver, Colorado
So I go into get an Oil change and come out with three leaks! I want to fix them all myself, but don't know where to start....Help Please.:emotions122:
Straightpiped
Maryland/Utah
Go buy a "Chilton" from the auto store and it will walk you through all of this. All you need is new gaskets/seals and remove/replace. I am not sure if the suspension will get in the way at all with the oil pan but it is a possibility. The Chilton should address that. Is the diff just leaking out of the rear? If so, thats an easy one. Where is the transfer case leaking? My guess is the rear. For that one you pull the driveshaft and pull the old seal and tap the new one in, in a nut shell.
048tahoe
