PDA
View Full Version : Pumping brakes after pad change
bigmike75
01-08-2011, 11:25 PM
I was so excited to complete my first pad and rotor change on my 03 Yukon XL that I neglected to pump the brakes until after I started up the car. The "Service Brake System" light came on for a second or two, then turned off as I pumped the brakes. I pumped them about three times, holding them down after the third pump. I then took it for a low speed drive around the block, applying the brakes periodically. I really didn't notice anything wrong but just wanted to see if something could have gotten screwed up.
Eagle
01-09-2011, 05:37 AM
nope. not as long as you didn't open the bleeder.
bigmike75
01-09-2011, 08:08 AM
No the bleeder is not open. Thanks Eagle!
bkboatnsleds
01-09-2011, 09:16 AM
Is not, or was not?
Not trying to sound like an ass - but if you did open the bleeder at all you will need to get the air out.. If not - should be all set...
bigmike75
01-09-2011, 11:02 AM
Is not, or was not?
No, I never opened the bleeder during the change.
bkboatnsleds
01-09-2011, 11:57 AM
Yep - than no worries, your all set.
Physh1
01-09-2011, 12:24 PM
Did you have to push the caliper piston in or did you get the new pads in & rotor in without doing that?
Cameron
bkboatnsleds
01-09-2011, 03:49 PM
I'd assume you would have to push the pistons in to make room for new pads..
jacket250
06-01-2011, 03:13 AM
yeal I think you have solven problems !!
Diablo 3 Items (http://www.mydiablo3items.com/)
blueflamed03
06-01-2011, 12:28 PM
5 months ago :)
