View Full Version : Hard transmission shifts
1weasel
06-29-2009, 11:54 AM
Yesterday, after some Interstate driving, I pulled into town and stopped at a light. When I took off, the shift from first to second was hard. I could tell it slipped quite a bit, then dropped in. It didn't matter how soft I drove, it did the same thing. This morning, on my way to work it was fine. I am thinking it's a heat issue and I am ordering a cooler, but could it be something else too?
bowtiefreak
06-29-2009, 12:10 PM
I had that happen when my valve body went
1weasel
06-29-2009, 01:27 PM
Another quick question, when putting the cooler on, which is the inlet hose and which is outlet hose going to the transmission?
bigpapapete
06-29-2009, 02:19 PM
leave the both lines off ,put the ends in a bottle or something to catch the fluid . the one with the fluid is the outlet from the tranny . also on the coolers the bottom line is the inlet for the cooler. thats the way mine is
1weasel
06-29-2009, 02:42 PM
The bottom? I figured that you would want it to flow from top to bottom. I don't know how much difference it makes though.
1weasel
06-30-2009, 12:04 AM
Does Dex VI work to fill the cooler and lines with? Or will mixing that with whatever's in there not a good thing?
vBulletin® v3.8.7, Copyright ©2000-2012, vBulletin Solutions, Inc.
