View Full Version : HIgh Oil Pressure
I have a 2008 Yukon XL. The oil pressure gauge started reading high, so dealer replaced sensor. Now it operates at idle or slow speeds with no load between 50 and 70 psi. My last Yukon never went above 40. Dealers says no worries, but I am. Any input appreciated.
blueflamed03
12-03-2010, 01:21 PM
50-70 psi at idle, or modertae RPM's?
yea, seems high to me....most are 25-35.
Okla-by God-homa
12-04-2010, 12:34 AM
Lets back up a bit. What oil are you running, what viscosity, any additives? Also what filter are you using. Lets start there and that should give a direction to head.
Last oil change was at dealer, so no clue as to oil and filter. Dealer changed oil last 2-3 times I took it in for high oil pressure. Right now in the cold, I start it up, and it idles at 50. 50-60 at moderate speeds even when warm. When warmed up really good, may ilde at 45+, but closer to 50.
Dealer's response was "its better to have high oil pressure than low."
k9lovr
12-06-2010, 01:00 PM
I would say the same with regard to the high comment, but too high can cause oil burn etc. Did you notice the change when the temps began to drop?
vBulletin® v3.8.7, Copyright ©2000-2012, vBulletin Solutions, Inc.
