PDA
View Full Version : Disabling/Removing daytime running lights
jmac572
06-24-2009, 08:05 AM
Thanks to this forum ive already recieved some great advice on which HID kit to get for my Yukon, now im wondering if anyone has any experience with disabling their DRLs... ive heared that there are a couple of fuses that you can remove but im not sure. thanks guys
Scotto2323
06-24-2009, 09:03 AM
Look in the manual and pull the DLR fuse. I think it is a 10amp, but I don't remember. Thats it.
Modded
06-24-2009, 12:30 PM
Get and HID relay harness with your HID kit and you won't need to disable them becuase the HIDs will be hetting power direcly from the battery, which will then skip over the low voltage DRL problem that messes up HID kits due to HID being connected to the cars HL harness.
The HID relay harness is all over the web!
jmac572
06-25-2009, 11:55 AM
yea, thats probably what ill end up doing... i was looking for a way to disable the DRLs though, so the HIDs are not on basically all the time, only when its dark out, so im going to try the fuse trick anyways, worst case is the DDM hi/lo kit comes with the harness at no charge
