PDA
View Full Version : 4WD light
wpnfxer
10-22-2010, 08:59 PM
Some times it comes on as soon as i start my Yuk up other times takes 20 min of driving then some times will not come on for a couple hundred miles. When it is on and i stop shut down and restart it most of the time does not come back on for 20 min or so if it comes back on at all. any help would be appreciated.
BlueTahoe2001
10-23-2010, 12:09 AM
Which Light? Im not familiar with the NNBS Trucks, so Im assuming they have the selectable switches and the orange dash light which says something like "Service 4-wheel"?
wpnfxer
10-23-2010, 10:35 AM
2000 yuk w/ push button selection and big orange service 4WD
stevek
10-23-2010, 01:24 PM
:mexsmoke:
03jbody
12-04-2010, 03:20 PM
I have an 05 yukon that has had the same thing happen to it. Not as often as 20 min of driving but the light would just come on when it wanted. took it to my mechanic and he told me that it was more than likely a short in the switch that was causing the message. I took the connectors off cleaned them and haven't seen the message since. Not saying that is your problem but that is what happened to mine.
dm600
12-27-2010, 11:27 PM
Selector switch or encoder motor sensor are about the only two items that fault on those trucks. Neither are too expensive for the OEM part at the dealer, if you can do the labor yourself. Wouldn't recomend most people taking apart the encoder motor to replace the sensor though. Of couse you need to read which code is setting in the TCCM.
libtechinit
02-04-2011, 08:40 PM
Not sure if your still having this problem but I recently bought a NNBS Tahoe and started having this problem a couple days later. Took it into the dealership and it ended up being the plastic connector to 4x4 actuator on the transfer case had gotten broken and would wiggle loose depending on road conditions and throw the service 4 wheel drive light. The switches and encoder motors on the NNBS Tahoe's don't really have many issues according to the dealership.
