Bolt torque for front seats?
snowjay
Does anyone know what I should torque the front seat bolts back down to when I reinstall them?
stevek
Dallas, TX
Did the same in my buddy's Mustang. We made them ratchet tight (as in couldnt turn anymore) then did a breaker bar probably 1/8-1/4 turn
shoop
Can anyone confirm the torque specs above?
When I went to remove the nuts in the front it felt like the nut closest to center console was barely torqued down compared to outer nut.
Also, the front nuts felt tighter than rear bolts too.
mikez71
Your seat bolts/nuts probably felt different because they were zipped on at the factory with an air ratchet or nut driver. Precise torque not needed.
The above mentioned values sound right to me.
Generally, listed torque values are standard based off fastener size, unless its something more special like headbolts.
shoop
Anyone know how to unclip these?
shoop
Thanks!!! Good info. I was messing with the yellow one hopefully nothing happened.
I did try sliding out a thin piece of plastic but not sure if that completely takes safety clip off. I tried disconnecting but nothing budged
where the small red arrow is push that little orange tab in the middle and the orange piece will slide off, then once that is off push the yellow tab where the large red arrow is then pull the harness apart, same process for the grey and black one, usually they are tight and may need to be wiggled a lot to separate them.
reassembly is the reverse, push the harness back together then put the little clip on the very end that keeps it from accidentally coming apart.
WITCH1975
