Whats the easiest way to drop 2"
whtout
Like the title says whats the easiest way to drop A tahoe rear 2"-
maybe even do a 1" in front and 2-3 " in rear-
I would still like to maintain a good ride, like from the factory-
I have a 2011 Tahoe- just put 22" wheels on it with a 305/40 r22 tire- and the fender wells have just a bit too much space- esp in the rear!!
I think I should have gone with a 275/45 tire-
NORCAL SS
SUV SUSPENSION GURU
so you know the 3/5.5 kit i have the rear trailblazer spring rides better than any 5 inch drop spring out there it even rides better than the djm or belltech 3 inch drop spring. I know you don't want to go that low but ride is much better out of those springs. Your other option would be to do the rear tb spring and add teh 1 inch belltech spacer but you will need to lower the truck in front about 2 inches to make that look right.
i would do the 2 inches in front with djm a arms and in rear my tb rear set up and you will be set to go. Will ride the same in front and in rear will ride better than stock. The rear tb djm springs ride really nice.
Jumpshot12
