PDA
View Full Version : help, trucks running a little rough
tybardy
06-19-2009, 01:47 PM
Ok guys, i just did a small road trip from phoenix to Pasadina CA...
I got in late last night and when i pulled into the hotel parking lot the trucks idle kicked WAAYYY down for a second, almost died... then this morning on my way to the store i think the truck was running just a bit rough...
any ideas? things to check?
(also on a side note, how can i tell if i have an exhaust leak at or near the exhaust manafold? It kinda sounds like there is one)
Rollin Thunder
06-19-2009, 01:49 PM
when it did the low idle thing were you parking?? Or already parked. Sometimes your powersteering pump will do that. Running rough im not sure.
tybardy
06-19-2009, 01:51 PM
man it was like 2am.... i was backing into the parking spot, i suppose i may have been turning the wheel one way or another... hard to recal exactly though
i really think i have an exhaust leak that may have worsened over the course of the 300 mile drive
Sepiroth
06-19-2009, 02:18 PM
Chances are that if you hear the exhaust leak under the hood, your leak is at the manifold.
If you hear the leak under the truck, it could be the Y pipe or other bolted part.
blueflamed03
06-19-2009, 02:35 PM
have a CAI?, double check all connections on it too...
Modded
06-19-2009, 05:39 PM
aif its the manifold atleast you can justify new headers!
blueflamed03
06-19-2009, 05:51 PM
intake gaskets, not exhaust gaskets.
tybardy
06-19-2009, 07:06 PM
yes but he is probably talking about my theory on the exhaust leak
Chris
06-19-2009, 07:11 PM
intake gasket, mine took a shit on me, ran rough at first then progressively got worse until it would shudder and die while idling. Start her up and drive her around for a few min then let it idle and see what happens.
tybardy
06-19-2009, 07:28 PM
how much is an intake gasket?
JennaBear
06-19-2009, 07:41 PM
Sounds like an intake issue for sure.
Chris
06-19-2009, 07:54 PM
cant remember exactly what I paid but not much <$60
tybardy
06-19-2009, 08:39 PM
curious jenna.... could this maybe have something to do with the issues i was having when Justin was tuning my truck... and has now just evolved into a slightly larger problem?
JennaBear
06-19-2009, 08:46 PM
Quite possibly. You might have a cracked intake manifold...
tybardy
06-19-2009, 10:01 PM
that sounds pricey.... how would i find out for sure?
JennaBear
06-19-2009, 10:32 PM
Take it to a mechanic.
tybardy
06-19-2009, 10:40 PM
fuck me! I was hoping there was a better way.... thanks guys, looks like its going into the shop when i get back into town
JennaBear
06-19-2009, 11:19 PM
You could do it yourself, but it does take time and you would need to read up a bit.
tybardy
06-19-2009, 11:28 PM
you wouldnt happen to be able to point me in the direction of the reading i need to do? i will probably take it to the shop anyways, but i also like knowing what i am talking about when the mechanic starts in with his high horse banter
JennaBear
06-19-2009, 11:42 PM
Google is your friend. You might be able to find some pics of what to look for too.
Max
06-20-2009, 01:40 AM
Manifold gaskets aren't too bad, but try to find a buddy you trust that will do it cheap first. Those things can be a serious pain in the ass if the gasket is all chipped up and gross, or you can just sack up and buy a blower from Jenna to solve the issue :cheers:
Rivieraracing
06-20-2009, 10:45 AM
Now that is a great solution to the problem!!! Go for it!!!:party33:
tybardy
06-20-2009, 12:45 PM
believe me, i would be all about getting a blower, just not enough $$ floating around right now. I am going to take it in for a diagnostic when i get back into town, if its going to require buying a new I.M. I will just drop the $100 on my warranty and get er done that way
blueflamed03
06-22-2009, 10:36 AM
if it is a cracked intake, I bet they are dime a dozen at salvage yards.
tybardy
06-22-2009, 11:13 AM
shit the jank yards around my house ass rape you on price! wanted to charge me $450 for a white HD hood... i know i can find it cheaper then that... if it is a cracked intake manif. i will just get it done under my warrante, i have a few other things that need to be fixed anyways
