PDA
View Full Version : Door handle broke on Driver Door
"350Vortec"
05-03-2009, 06:17 PM
Well my exterior Drivers side door handle decided to snap around the edges today. So now everytime i pull the handle the whole part of the trim around it pulls away from the door also. I see these handles on ebay all the time for replacement but i have no clue on how to get it off, And how would you replace the lock so your key will still work with it?
tahoe ss
05-04-2009, 04:00 AM
good luck it was a pita for me
WH0DAMAN
05-05-2009, 12:35 AM
Pull the trim panel off. Basically you pop off the trim ring around the inner door handle, the trim cap behind the mirror and the window/lock switch/tweeter unit. Make sure the window is up and then unplug the switches. A small standard screwdriver might help with this. Then pull the door trim panel out until the clips are clear and then pull up. Door panel is held onto door shell with two piece plastic clips. Once the trim panel is off remove the vapor barrior toward the rear of the door. Remove the bolts to the door lock located on the jamb of the door. This will make installation much easier. Disconnect the rods going to the handle and the lock cyl and remove the handle. Install your old lock cyl in your new handle and install handle in door. Put everything back together.
