Anyone know where the High Beam Relay is??
derk
Saskatchewan
i have a 07 tahoe and I cannot find the high beam relay under the hood in the fuse box. its not listed on the fuse box cover. When you turn high beams on and off you can hear a click sound comming from the fuse box. And it does not share the same relay as the low beam. it almost sound like it comming from under the fuse box. I tryed pulling the 2 gray handles up to look under the fuse box but i coulndt figure out how to get under there.
Any help would be aprecated.
Thanks
Derk
FuzzyChopz
I'm pretty sure the clicking youre hearing is from one of the relays underneath the cover. The fuses for the high/low are in that box. Try having someone switch from high to low while puttting your finger on the relays and you will feel the clicking. Which ever one you feel clicking is the right relay for the high beam.
dm600
High beam relay on most 07 Tahoes is what is called a PCB Relay. Printed Circuit Board Relay - meaning it is not something that you can just pluck out of the fuse block. To replace it the fuse block must be replaced. Not sure what you are looking to do but if you want to replace it without replacing the fuse block you will have to dis-assemble the fuse block and locate the relay and then probably de-soldier it.
Jumpshot12
