Pretty Desperate For This Part...
FLtahoe
Florida, USA
I recently saw this center console rear radio insert and can't find a part number for it ANYWHERE. My console just has an empty space where the radio controls go (it's an LS and I put it in place of the jump seat). Its such an eyesore...any help would be very much appreciated. Thanks!
zach2011
Platinum Member
If worse comes to worse you could always buy that console, remove the piece you want, and re-sell the console. I have tried looking for you and I even asked that seller and they wouldn't give any part numbers.
F
FLtahoe
Florida, USA
Thanks man! I did the same thing too and the guy won't give it up...not sure why, but oh well. Appreciate the help though man.
F
FLtahoe
Florida, USA
Thanks for the info, but that isn't it. I have an LS, so rear radio and temp controls are not an option. That's why I'm looking for this insert to go in there. I appreciate post, unfortunately it's not what I'm looking for.
stevek
Dallas, TX
Oh sorry I misunderstood. I'll look again.
---------- Post added at 09:42 AM ---------- Previous post was at 09:35 AM ----------
I don't know if that comes with the center part in there or not, but the part number is there... #12
http://www.gmpartsgiant.com/compone...d~console-floor-tc169820116-lmmm30k10706.html
F
FLtahoe
Florida, USA
Thank you for helping me track this down. The part just came this morning and of course it needs to be installed from the inside (ie. you can't just slide the tray in from the outside). I didn't have time to really look at how the console was put together, but I'm hoping I don't have to take the whole thing out just to put this part in.
IrishTR
San Antonio, TX
Should just be them outter backet bolts on the sides and then maybe some inside the storage box to get up off ground enough to see from underneath then just attach probably by 1/2 screws each side.
GL
F
FLtahoe
Florida, USA
I actually put it in the other day. The face (for lack of a better word) just pulls off and you can attach it pretty quick. You do need to use some force though to pull it out. I was a bit nervous about breaking something.
billy76
Hollywood, FL
What about power?
There's an accessory power outlet on the back of the console under the cubbyhole hole. Is a wire already run for that, or do I need to run one?
F
FLtahoe
Florida, USA
mine isnt wire ready. it's just a hole with the cap over it. if you end up getting it to work, let me know. i wouldn't mind getting it functional if its a pretty simple fix.
WITCH1975
