92 GMC Yukon voltage problems
Rock of Gilead
I have a 92 GMC Yukon, and when it would crank up and run the voltage gauge fluctuated. Now it wont crank up at all. I thought it might be the fuel pump but I tested the fuel pump by taking a plug it from an old fuel pump cutting the ends off the wires and sticking it the battery. The pump runs perfect when attached to the battery, but it does seem to prime when the ignition is turned. Any ideas?
h0tr0d
Brenham, Tx.
The Technical forum is for Write-up's on Mods, and maintenance to your Tahoe or Yukon. If you have a problem you are trying to find an answer to please post it in the General Disscusion forum or the section that suits it best.
R
Rock of Gilead
Oh, I posted it here because I saw about a hundred posts that had be moved here that were tech questions about repairs and the like.
h0tr0d
Brenham, Tx.
No problem. I'm just trying to let you know why nobody has answered your question yet. Most people only visit this section to reference an old write-up someone did to help them solve a problem.
JamesinAbilene
