PDA
View Full Version : 2000 s10
yukondoit
08-13-2010, 01:58 PM
Well my daily finally broke down. It went down due to a transmission fluid leak. One of the hard lines ended up getting a hole in it... it was rubbing against a electrical connector. I attached some pics.. I want to know if they sell the hard lines as a set or individual? Would I be able to do it myself or better left to the pros? Its the lower hard line that connects to the bottom of the radiator.
http://i689.photobucket.com/albums/vv252/yukondoit_photos/P1010991.jpghttp://i689.photobucket.com/albums/vv252/yukondoit_photos/P1010990-1.jpg
96ProCompTahoe
08-18-2010, 11:31 PM
s10's are a dime a dozen at the salvage yards, should be able to pull one without much trouble and swap it out.
redemn93
08-19-2010, 11:04 AM
to can buy hard line at napa and cheap bender. that would be be easy to make.
or what i did was get a good quality rubber trans line and routed it. just cut a couple inches behind the end of the line and use good hose clamps and slip the rubber over the hard line. very easy and cost me $5. i went 60k miles before i sold it and it was still perfectly fine.
yukondoit
08-23-2010, 12:41 PM
Thanks guys for the suggestions. I got it fixed, but now I found a new leak. The upper hard line that connects to the top of the radiator is stripped out... Looks like I'm going to be buying a new radiator, again. This is the 2nd one within 3yrs..
96ProCompTahoe
08-23-2010, 09:23 PM
you gotta hate those aftermarket radiators with the brass adapters. such a pain to get them lined up perfectly.
yukondoit
08-24-2010, 10:41 AM
Exactly.. :nono:
Hopefully I'll have a new radiator by the weekend.
