Polyurethane Bushings
Crispy
Slate Belt, PA
Had them on cars I've owned. They stiffened up the ride a bit, but its also hard to guage since the OEM bushings were shot. Generally poly bushings are known to be stiffer than OEM rubber and they last longer. If your truck has original bushings, anything would be an upgrade at this point.
retorq
Kingman AZ
I've got them, no complaints, do get yourself a tub of that grease. The lil pack they send is not nearly enough.
TigerEyz3
Slow and Steady
TN
I'm with retorq... they improve the handling and road feel quite a bit, but if not lubed well will squeak.
WITCH1975
