Just installed new window motor
Jaycenk
Florida
Installed a new window motor in the rear driver side door in the hoe and man was she bisoch!!! I hate windows. So the rear regulator has no provisions for locking it in position while you change the motor. Just an FYI to anyone going to do it, if the motor stoped working take the back motor housing off and spin it by hand to get it to the desired location and then once it is out you can wind it all the way down and then drill a hole from the motor bracket through the regulator and insert a screew that will keep the clock spring from ripping your hand off and keep the regulator in position untill you install the new motor. Good luck with yours, now I have to change the regulator in the front driver door tomorrow...uhg!!!.
Also the instructions tell you to remove the regulator by the factory manual. They are no help at all. Also the hanes manual is a POS, NO HELP AT ALL ( I knew this before I got it). needless to say I will be tracking down a factory manual for this thing very soon. I hope the driver front is not as much of a PITA.
048tahoe
