PDA
View Full Version : Stuck on DEFROST!!!
Rockstar
06-17-2010, 11:17 AM
Cant find a vacuum leak. Heat n AC work. But the "blend" indicator just blinks. Befor it would only switch between df dash and floor, wouldn't.
Da90
08-04-2010, 05:56 PM
Mine does the same thing! Find anything out on how to fix it?
riviera rider
08-04-2010, 06:28 PM
when mine was stuck on defrost i changed my climate control on the dash, my rca wires made it short out and you could see it was burnt up in areas since the board isnt covered
Da90
08-05-2010, 09:51 AM
Are you are talking about the switches? I just put new OEM controls in and it still does it! My 97 SWB did the same thing and I also put new controls in it. Still same problem!?
riviera rider
08-05-2010, 06:41 PM
damn them switches aint cheap i spent over 100$ on mine and ive went thru 3 of them lol
Mex-Nali
05-08-2012, 08:57 PM
My '04 did the same thing after I replaced the battery. Thinking something was up, I googled it and on page two I found this gem:
Turn the climate control and the radio off.
pull the fuse under the hood marked hvac/ecas 10 amp in the right side
Leave the fuse out for about a minute.
reinstall the fuse.
******do not touch the c.c. switch when you restart the truck******
restart the truck, the c.c. will automatically reset to 74* and start cycling.
it will take about 1 min for the c.c. to reset itself, you should hear it running through the cycles.
there has been one or two times I've had to go through this procedure a couple of times for it to reset.
Worked.
SunlitComet
05-08-2012, 11:57 PM
Wong year forum buddy.
