View Full Version : Has anyone swapped autoride with standard shocks?
graphicideas1
06-08-2009, 10:06 AM
How is the ride? Did it improve or stay the same?
NORCAL SS
06-09-2009, 11:45 AM
pretty much under tow conditions is changes thats about all. Ive pulled the rear air set up and replaced with djm shocks and put from 2-5 inch drop springs in rear and its fine.
warrlac
06-09-2009, 09:14 PM
:emotions122: My experience is a bit different. I installed a Belltech 2/3 drop kit. Left the rear autoride shocks on (with shock mount extensions) but swapped the fronts out for the shorter Nitro-drop shocks...
What I found is that Autoride more or less ceases completely. You get the big orange Service Autoride System warning and a really rough ride.
Note: I did not install the "Autoride Indicator Lite Eliminators", which are some 1/2 watt 3.9 ohm resistors (from what I hear).
My plan is to go with McGaughy's drop spindles, take out the Belltech drop keys and put the stock keys and Autoride fronts back in.
That way I'll have four Autoride shocks on each corner with the same geometry as stock.:)
tann808
06-09-2009, 09:34 PM
I recently purchased my '02 Yukon Denali and installed a 2/3 McGaughy's Deluxe drop kit but I noticed that my rear Auto Air Ride shocks were leaking and the compressor was turning on every 10 minutes and due to the 3" rear drop it would constantly bottom out (very annoying)
I priced out some Auto Air Shocks and it ranged from anywhere from $599.00 to $1200.00 (that's insane!)
That's when I looked into McGaughy's Air Helper Kit (approx. $150.00) the kit is basically an airbag that goes inside of the rear springs.
http://www.clublexus.com/gallery/data//500/air_bag_2.jpg
I have the air hose nozzle (included in the kit) located next to my hitch for easy access but I'm looking into having it hooked up to a compressor so I can lower or raise the PSI in the cab.
http://www.clublexus.com/gallery/data//500/air_bag_1.jpg
I highly recommend these! Very good bang for the buck and since the rear never goes lower than the Auto Air Ride sensor, it'll never turn on the compressor.
It'll be cool if somehow I could use the Auto Air Ride compressors for the Air Bag Helper Kit. If anyone has any ideas, please chime in.
If your Auto Air Ride is shot and needs replacement...we have an alternative to purchasing new Shocks. I'm pretty sure that this kit was designed for the McGaughy's rear springs but I'm sure there are some type of universal firestone airbags that'll fit the factory springs.
Hope this helps?
Modded
06-09-2009, 09:42 PM
I didnt know that bags could serve as rear shocks too, its funny that almost all GMs damn Autoride shocks have that BS leak problem!
vBulletin® v3.8.7, Copyright ©2000-2012, vBulletin Solutions, Inc.
