Whippled2dr
06-06-2009, 03:34 PM
I installed a hydroboost setup on my 2 door tahoe two weeks ago. The whipple and intercooler will be back on in a couple of weeks.
Parts:
- Hydroboost and Master cylinder from local junk yard (98 HD truck)
- New AC Delco steering pump for a hydroboost truck
- Ebay Mounting plate with centered whole
- Hydratech aeroquip hose and fitting kit for my application
- Various stainless nuts and bolts from mcmaster
- 3/8-16 thread die for the hydroboost pushrod
- Ac delco brake light switch
- Steering and brake fluid
I took the snap ring off the unit and unscrewed the retaining nut with a big adjustable wrench and test fitted the new plate. All fit perfectly and the holes of the new plate matched the stock plate holes.
(I used this centered plate because I used the stock brake pedal).
I bought the plate from ebay from the seller sterlingworth16. It is 3/16" thick steel.
http://motors.shop.ebay.com/merchant/sterlingworth16_W0QQ_nkwZQQ_armrsZ1QQ_fromZ
http://i3.photobucket.com/albums/y73/99bluetahoe/Tahoe/Hydroboost/IMG_0091.jpg
http://i3.photobucket.com/albums/y73/99bluetahoe/Tahoe/Hydroboost/IMG_0090.jpg
http://i3.photobucket.com/albums/y73/99bluetahoe/Tahoe/Hydroboost/IMG_0087.jpg
http://i3.photobucket.com/albums/y73/99bluetahoe/Tahoe/Hydroboost/IMG_0088.jpg
Pic of the master cylinder.
http://i3.photobucket.com/albums/y73/99bluetahoe/Tahoe/Hydroboost/IMG_0086.jpg
I cut and threaded (3/8-16) the pushrod making it shorter by +- 5 mm. Once I get my vacumm booster off I'll measure and adjust the rod to the same length. The joining nut is stainless and 1-1/8" long. By doing this and using the center mounting plate, I can reuse my stock brake pedal.
End result:
http://i3.photobucket.com/albums/y73/99bluetahoe/Tahoe/Hydroboost/IMG_0082.jpg
http://i3.photobucket.com/albums/y73/99bluetahoe/Tahoe/Hydroboost/IMG_0084.jpg
http://i3.photobucket.com/albums/y73/99bluetahoe/Tahoe/Hydroboost/IMG_0085.jpg
Hydratech hose and fitting kit for a 99 tahoe. These are Aeroquip TFE high pressure hose and fittings. Great service and packaging on hydratech's part.
http://i3.photobucket.com/albums/y73/99bluetahoe/Tahoe/Hydroboost/IMG_0092.jpg
Before
http://i3.photobucket.com/albums/y73/99bluetahoe/Tahoe/Hydroboost/IMG_0109.jpg
After
http://i3.photobucket.com/albums/y73/99bluetahoe/Tahoe/Hydroboost/IMG_0112.jpg
http://i3.photobucket.com/albums/y73/99bluetahoe/Tahoe/Hydroboost/IMG_0113.jpg
http://i3.photobucket.com/albums/y73/99bluetahoe/Tahoe/Hydroboost/IMG_0114.jpg
Filthy!
http://i3.photobucket.com/albums/y73/99bluetahoe/Tahoe/Hydroboost/IMG_0115.jpg
http://i3.photobucket.com/albums/y73/99bluetahoe/Tahoe/Hydroboost/IMG_0119.jpg
http://i3.photobucket.com/albums/y73/99bluetahoe/Tahoe/Hydroboost/IMG_0120.jpg
This setup has been on for about two week so far and has worked great. I actually had my first panic stop yesterday and was glad I did the swap.
Parts:
End result:
Before
After
Filthy!
