View Full Version : broke leaf springs
MUDDER TRUCKER
04-09-2010, 07:42 PM
guess i had sloppy u bolts, snaped the top load spring and bottom helper spring. bought used springs for 50 bucks. put my 3 add a leafs in the new pair. just waiting for the bushings to get here. here are a few pics.
http://i179.photobucket.com/albums/w294/brtreeservice/005-13.jpg
http://i179.photobucket.com/albums/w294/brtreeservice/003-17.jpg
http://i179.photobucket.com/albums/w294/brtreeservice/002-21.jpg
http://i179.photobucket.com/albums/w294/brtreeservice/004-19.jpg
branndon_b
04-09-2010, 08:17 PM
that's crazy right there.
MUDDER TRUCKER
04-09-2010, 09:22 PM
yeah i had to do like 20mph to get home, every time i hit the gas or braked the axle moved about 3-4 inches. that could have been bad.
T-Bagg
04-10-2010, 11:44 PM
How'd you do that? I just took mine out to the desert and was putting her over jumps without problem.
MUDDER TRUCKER
04-11-2010, 09:54 AM
beats me man...and i have 7 springs.....haha i must beat the piss out of it more than i thought
bowtiefreak
04-12-2010, 07:18 PM
I've been bending the centering pins but never broke a spring yet. Good thing you caught that.
99COOP
04-12-2010, 09:13 PM
You should have that shim under the block, not on top. That could have caused the stress needed to break the overload spring. I have also seen a lot of blocks with the spring angle shim mounted on top of the block get spit out from the axle. Might want to rework that setup.
MUDDER TRUCKER
04-12-2010, 09:21 PM
i had the shim bolted to the spring pack. was thinking about removing the shim completely
MUDDER TRUCKER
04-16-2010, 11:51 AM
got everything all bolted back in and new bushings! time to get tires rims and 3in flares!!!
vBulletin® v3.8.7, Copyright ©2000-2012, vBulletin Solutions, Inc.
