mikeykey
06-02-2009, 11:27 PM
I have this same switch set-up on my boat and have been wanting to do it on my hoe for quite some time now. I finally got off my arse and did a little write-up.
The switch itself is a marine grade switch, found at many marine shops (I got mine at west marine, $30.00)
http://i53.photobucket.com/albums/g59/nbpdmjk/tahoe021.jpg
I then made a bracket to screw the base of the switch housing to
http://i53.photobucket.com/albums/g59/nbpdmjk/tahoe022.jpg
I then un-screw the OEM fuse holder and secured my bracket using those screws.
http://i53.photobucket.com/albums/g59/nbpdmjk/tahoe024.jpg
I then hooked up both batteries to their respective posts and attached all the commons to that post.
http://i53.photobucket.com/albums/g59/nbpdmjk/tahoe026.jpg
The entire job took about an hour front start to finish. Most of that time was running the 2 gauge wire over the fan shroud and crimping the connectors on.
This particular set up works great for me because with a dual battery set-up, if the truck sits for an extended period of time, the batteries will actually start to effect negatively towards each other and lose their charge. I don't drive my hoe but once every week or so, so when Im not using it, i flipped the switch to "off". Acts as some what of a security system too.
