Air Intake?
HotCarl
ID/WA
How much is gained from replacing the stock intake assembly with an aftermarket one?
I am rocking the stock intake setup, with just a K&N filter inside. New intake kits range from $100-$300. Are they really worth it?
blizz
San Antonio, TX
I was about to ask this same question. I have a K&N filter in the stock box and really want to get a new kit but I want to make sure that it's actually going to do something and make it run better and/or add some performance or mileage. A Spectre is going for $150 and K&N for $225.
Chrislovessushi
Murderedish
SC
did you guys notice a difference after dropping in the k&n filter in the stock box?
DJTricky
Banned
Robbinsdale MN
is can cost you anywhere from 30(mine) to 250
just look around. use search and find some of the older threads but just a peak, you can make your own if you are handy enough
bai78
Surviving
Dallas, TX
It gives that grumble with the new intake tube. MPG's are up a bit but there isn't a noticeable increase in hp or torque.
992dr
Eastern N.C.
No noticeable difference here, other than being able to hear it suck the air in. Sounds cool though.
I wouldnt expect much from just a CAI.
JamesinAbilene
