View Full Version : lifting promblem
tom10
06-02-2009, 09:34 PM
heres my long problem....ok so i have a 93 full size blazer and i put a 1 1/2inch lift block in the rear and got new torsion keys and lifted it 3 inches in the front and it was stiff.... well i went to get the tired aligned and the guy told me i cranked the torsion bars to high and my control arms had no clearance from the frame he loosened the torsion bars and i pretty much lost my lift he said i had to get the control arms drilled out so they can move freely.....so my question- is there a way to lift my front end up and not have the problem with the control arms?
bowtiefreak
06-03-2009, 07:23 AM
Getting a real drop lift will fix that. 3" is a lot of crank for the front, 2" max and that will still be still. many 6" kits out there are a 4" drop that is cranked for the other 2". So that would put you a bit above where you were with a little room for growth. The extreme suspensions kit is a true 6.5" drop that can be cranked up to about 8" no problem.
tom10
06-07-2009, 01:24 AM
well i wanna lift the front end higher for a bulldog look but cant really spend all the money for a new suspesion kit....any ideas
bowtiefreak
06-07-2009, 11:35 AM
it sucks but save up and do it right, it will save you a headache.
vBulletin® v3.8.7, Copyright ©2000-2012, vBulletin Solutions, Inc.
