Tahoe 2010 with CAI & Magnaflow Help !!!
tahoe2010
Hi ,
my Truck is Tahoe 2010 5.3
i install magnaflow exhaust 10 days ago ( amazing )
and every thing is ok
yesterday i install Volant CAI after that i run the car for test
its awesome sound but i feel like i had some problem with RPM when
the car on idle ,,, little up and down (not stable ) specially when i am stop after run the car.
Then ---- Today
after i go to round trip about 30 mile when i stop the car shut off
i restart the car and run again when i stop the car ,,,, the car shutoff again
and i feel like there is something not stable on my engine ( little vibrate ) and the RPM going down about 300rpm
So, What should i check ??
Thanks in advance
Bob
UofMZ71
make sure that the cold air intake is plugged in correctly, and also tightened down. other than that i really dont know.
JennaBear
Resident Ninja
San Diego, CA
Folks with 09+ running Volants have had issues running rich. Some have stated that they were told to use an O-ring for the MAF, that was enclosed in the packaging but not addressed in the instructions. Did you install that?
T
tahoe2010
No Sir ,
there is no O ring .
JennaBear
Resident Ninja
San Diego, CA
I would definitely give them a call. We have had a lot of customers who have had issues with these intakes, it is a matter of the intake forcing the MAF to read wrong.
mtbennett24
I have an 09 5.3L. After installing the Volant CAI, about a week later the check engine light came on. I never had any idling problems though. I unplugged the battery for an hour, although some said 20 min should do it. Reconnected started up and no CEL now. I ran a OBD2 code reader and there were no codes pending or present. When the CEL was lit up, Onstar said that the problem was with the "engine fuel control system" I am thinking that unplugging the battery helped reset the computer. It is likely that the computer is still learning from the MAF and maybe the light could go back on. Haven't got that far yet though.
T
tahoe2010
Thank dude
madrule2002
what type of filter did u ordered from volant website 4 inch or smaller
jee123
that sucks man hope you get it fixed...maybe take it off and reinstall it. sometimes it helps
dmerk1978
Long Beach
i have a better question, i'm unaware of the 2010 magnaflow even being released, are u running a 2009 exhaust on a 2010 truck?
madrule2002
MSRP:
$765.23
PART #:
16564
YEAR:
2009
DESCRIPTION:
V8 4.8L
5 x 11 x 22 in. Muffler, 3 in. Tubing; 3.5 in. x 5.5 in. Oval Tip, SINGLE REAR SIDE EXIT
SOUND_CLIP:
No Media Clips Available
DYNO RESULTS:
No Dyno Sheets Available
INSTALLATION:
Install Sheet not available
CHECK INVENTORY:
Check Availability
bro check the info its written 2009 , i am not an expert but maybe 2010 MF for ur car not released yet
dmerk1978
Long Beach
i'm not sure either, all i know is that a 2009 should not fit a 2010, unless custom fitted by the installer, i'm unware of any exhaust being to market on 2010 unless custom made or r&d from the manufacturers. just my 2 cents
Zed 71
Pacific NW
IMO the 2009 should fit 2010. I am not aware of any changes that would affect exhaust fittment. However, the CAI for 2009+ are definitely not compatible with previous years because the MAF housing is different.
My previous post was regarding mad's where he indicated the exhaust was not compatible because of the MAF. There is no direct correlation between the exhaust and MAF fitment wise.
Volant1
Volant guy
Upland, CA
If the battery cable is not unplugged or the o-ring is not swapped out your kit will through a check light did you get the problem fixed?
048tahoe
