mk04Yukon
06-02-2009, 11:30 AM
First post here. Wanted to start off saying thanks for all of the knowledge shared here - it has definitely been helpful. Wanted to get everybody's thoughts on what i'm thinking of using. Here is my list that I'm going to tackle this weekend on my 2004 Yukon SLT (5.3L) 60K miles:
Transmission Fluid - pan drop/filter change - going with RP Max ATF fluid
- I checked the transmission cross reference chart on the RP website and should be ok with Max ATF. Anybody think any different?
Front & Rear Differential - going with RP 75w-90
Transfer Case fluid - not sure on this, should I do it since I'm down there? Do I need to get the blue stuff from the dealer?
Coolant flush - was thinking Peak - any thoughts should I go with the pre-mixed stuff?
Brake Fluid - was going to go with best priced Dot 3 that I find at the store - any thoughts?
Change the fuel filter
Also going to lube the grease fittings - was just going to use some molly grease. should I be using something else?
Any thoughts, recommendations or tips are appreciated. Thanks again
