Problem with drop!
josetizapan
Iowa
I finally droped my denali but i have a problem now my pass side is about 1 and quater lower then my driver side and its rubing like crazy in every little bump what would be the problem?
I have a 1999 Denali 4wd with keys at front and shackles in the back and tires im runing with are the 305-35/R24.
josetizapan
josetizapan
Iowa
No i did the 2/2 drop on it and rear is fine no rubing and i still got some clearance but its just the front passenger side is 1.25" lower then my front driver side i have no problem with my driver side rubing but i called the guy that installed them and he said just to turn the bolt on the key and that should fix it.
branndon_b
Lake Charles, LA
wonder if it's the ball joint on top? just a thought there. may be way off, but since you changed the geometry of it maybe it put it in a bind? dunno.
josetizapan
josetizapan
Iowa
I got it fixed now i checkd the bolt of the keys and the one in the pass side was out more so i just screw it in the same distance of the driver side n it fixed the high issue n no more rubing.
josetizapan
josetizapan
Iowa
pics inside
hey i need to see a pic. i also have a 99 denali but with a 4/4 w/255/30/22.
Here's a pic that i took with my cell when i got done putting the wheels so the quality of it is bad. The second pic is how it use to be with out the drop.
veteran111
