Where can I pick up a new lower door hinge? I'm in Germany and the nearest dealer is 3 hours away. My door makes a horrible racket everytime you open it fully because the damn wheel/roller bearing thing is not rolling with the door.
The hinges are actually "glued" on. There are bolts aswell, but swapping the hinge isn't easy. The alignment to the door is almost never back to the way it was and closing it will be weird
Is it lubed? Can you post a picture and maybe we can suggest a solution
If you want to fix it get some grease called "3 in one". Your roller has gotten stuck / rusted so its not spinning at all. It makes a NASTY sound too! Grease that baby up and work the door open and closed. It will be as good as new!
Fixed yet? I did take mine to the dealer and like I said, it was not covered by extended warr. They did not say anything about the hinges being glued on. As a matter of fact made a point to say that he was happy that they are just bolted on as opposed to some of the older ones where they were welded on and had to be cut off.
Mine did this exact same thing. I sprayed white lithium grease on it and it still did it. So I went to the dealer and of course my extended "it covers everything warranty" did not cover it so I waid fugg it and waited. As soon as it got a bit warmer I think that the grease had a chance to work in there and the wheel is rolling like new again.
I would try to get a hold of it (the wheel)with a pair of needle nose channel locks and turn it manually while spraying wd40. As soon as it frees up spray a grease in there, it has more "sticking power".
