I messed up
Modded
That Guy
Well lnog story short, the other day (like many of yall know) I installed the rear Pedders kit. Today I finally get around to doing the front and after removing the front left strut and compressing the spring I notice a huge mistake.
I accidentally put the Pedders 2424 coils in the rear!:Frustrated:
Yeah so that means the strut front coils were in the back, so I then had to bolt the WHOLE front strut/coil back up and then go back to the back and remove the 2424 front coils and replace them with the 2425 coils! Yeah I had no idea that I could make such a stupid mistake, I was pretty pissed.
So after fixing the mistake and installing the correct rear coils, I then had to just leave the front till Monday when I have another chance to do this stuff.
I'm only posting this because I don't want anybody making such a time costly mistake, and to let those who saw the old drop pics know that the rear sits lower than before (with the mistake 2424 coils) which makes me happy!
I'll post pics eventually......
BOSS
The People's A D M I N
Dallas
Damn man.....that sux balls. We've all done it before in one way or another!
BOSS
quick66ss
Columbus Ohio
Don't feel bad. The kit comes with no instructions. I have a few suspension rebuilds under my belt and I had to scratch my head when I unboxed everything. I ended up putting one of the rear springs in upsidedown:emotions122:.
I love the way the Tahoe looks now but, was expecting a more sporty ride. The wife drove it this week and said it rode the same as when it was stock.
oakster
Massachusetts
Super easy mistake to make but better to have to swap out the rear springs than the front ones
Modded
Modded
That Guy
Thanks for the relief guys, and Oakster your right, if I had to swap the front springs due to a mistake like that I would jump out a real high window!
---------- Post added at 09:38 PM ---------- Previous post was at 09:35 PM ----------
And Quick66ss I noticed a good amount of a sportier ride and I don't have the shocks like you. You may not notice it much because you drive it everyday, drive a stock Tahoe and you'll feel the difference. ALso try higher speed maneuvers and you'll feel some more differences.....
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
That sucks man! It's a good thing you caught it before you completed the install in the front... That would really suck too.
Modded
Modded
That Guy
Iwaslowr how dark is your front window tint, 5%?
---------- Post added at 02:58 AM ---------- Previous post was at 02:57 AM ----------
And did you ever install that Belltech kit?
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
5% on the front doors but the windshield is completely tinted with a layer of 50% plus the upper and lower 5% brows...
... And did you ever install that Belltech kit?
I still haven't had time to do the front yet... but am getting getting tired of the Cali lean. Needing a spring compressor and bushing press is not helping either... :shocked:
Modded
Modded
That Guy
Dam, how do yall Austin boys (you and JK) pass inspection with those windows, or even go about withou getting pulled over? I'm in TX too and afraid to do that.
Also I am tired of my Cali Lean so I will be doing the front lowering on Monday, just to let you know you can rent a sping compressor at no charge from your local O'Reillys Auto Parts or Auto Zone, its what I did.
What is and why do you need a bushing press?
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
The tint is not really that dark. I've had double limo on my previous vehicles and wasn't bothered by cops with that either... I wouldn't do that on an large interiored vehicle though, seeing out at night is a must! But there was a time when a Tropper harassed me for having 20% after passing him at 70MPH(I wasn't speeding).
You just have to be careful... If there's a cop nearby the windows are down before five seconds pass. And if I do get pulled over, ALL windows are rolled down for the duration of the encounter.
Thanks! I'll have to keep that in mind... :Handshake:
The darn Bell Tech kit came with camber bushings which may or may not be needed. According to the instructions if the struts are used at their lowest setting(no spacers) the bushings are required for the alignment to be at or close to OEM specs. The struts yield up to a 2 inch increase or decrease in height utilizing the stock springs, but I have not heard of other kits needing these bushings? It would seem to me that all kits with 2 inch lower springs would also need this camber bushing mod... ?
I plan on using the 2 inch spindles then finding the exact 1/4 inch at which I'd like the truck to be at from that point by adjusting the strut spacers. JK's stance is NOICE!!!! :worship:
Modded
Modded
That Guy
Oh ok I got you now. I was thinking the strut thing would be Alignment kit related. I suggest you use the 2" lower spindles you metioned with the shocks on full height. After all you'd be lucky to pull a 3" front drop with 26s without alot of mods.
So back to the tint thing, is there a reason why you just did the top and bottom of it instead of the middle?
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
I've always been told "You can't do that" or "You won't be using that as a daily driver"... but I did, and do.
The whole windshield is tinted with 50% and there is also 5% upper and lower brow... So the brows are actually 50% plus limo. Tinting the entire windshield with limo would be CRAZY DARK... even with all windows down, I'm not about to pay that ticket or re-tinting!!!
Modded
Modded
That Guy
Hell yeah I agree with you, that ticket would be GAY, after all I got a "BlackedOut tails" ticket for $200 that was alot of BS!
dms
SF Bay Area
Takes a real man with integrity to admit this!! But not big deal. Rear coils are pretty easy to replace. Thanks for sharing
mike
dms
veteran111
