bottom of tailgate weather strip driving me nuts help!
lovemyyukon
Can someone please tell me how to attach the bottom of the weather seal on my 2004 Yukon as it pops of every time I open the door:emotions122:
---------- Post added at 10:26 AM ---------- Previous post was at 09:04 AM ----------
My question is how do I get it to stick. Do I use a glue of some kind that will work or do I need new strip?
cam3439
If it still seals fine, but doesn't stick then I would put some glue. Mine started to fall off when I went to the beach, but it still sealed fine so I glued it. I used some epoxy glue, which turns into hard plastic. So, you don't need that much for it to stay glued with epoxy.
armandjones82
Banned
I might suggest that you might try to change up your weather strip if it would drive you nuts again. Brands such as fairchild industries among others can be a good thing to have in order to really make things work out next time. And for sure, you won't use epoxy if you buy a new, more durable weather strip.
westcoast
Salinas,CA
it happened to me on my tahoe just right in the center where the two meet due to my kids getting in and out I used weather strip glue from autozone.
Jumpshot12
