Rubbing
99denali
alabama
Ok, so probably nothing and a noob question but i figured id ask anyways. I have a stock yukon denali with 265/70/16 tires...and it rubs a little. is that normal or has my front end sagged a little or something else and caused it? It doesnt rub terrible but just on some of the steering componets. Just a wonderin.
josetizapan
Iowa
I have a 99 denali also and im running 265/75R16's and they dont rub at all. My denali dont even rub when i put my big wheels on it in the summer. But like kris said are runing stock wheels?
99denali
99denali
alabama
Im running the stock wheels it came from the factory with, and it rubs when turning.
boble94
GM All The Way!
Lincoln, NE
well something isnt right. my factory wheels are 245's and they were to small so i upgraded to 265. but mine doesnt rub at all when turning. so could it be sitting lower than normal? do you have any pics?
maybe a pic on the side so we can see the stance and one with the wheels turned. maybe someone could help you if you posted some pics. Just a suggestion.
smrr1
should not be rubbing. running 285s w/stock wheels and no rub.
99denali
99denali
alabama
Yea ill see if i can get some pics up eventually, im getting it lifted soon so when i get the cash so once i get it lifted that should clear up alot of the problems hopefully.
boble94
GM All The Way!
Lincoln, NE
so i'm guessing you might wanna check something out because we are running 265's and no rub and there are some running 285's with no rub.
WITCH1975
