Need help wiring escalade Bvlgari clock.
denalianyone
NYBlackLade08
New York
I just received my escalade bvlgari clock and connector. The connector has three wires and did not come with any instructions. I cant find any tutorials online to installing this. Did anyone do this mod b4? Any help will be greatly appreciated.
Grebbler
Parts is parts...
Michigan
I have never seen the clock. If it's just a normal clock I would assume the leads are Ground, B+ for clock and the last lead for the light to tie into the dash dimmer circuit.
denalianyone
denalianyone
NYBlackLade08
New York
The clock is standard in the 02-06 escalade models, incorporated into the power/storage section of the center console. Thanks for your quick advice.
ndavis0001
Davis Motorsports
Jacksonville, FL
well you could do a soft test... run your 3 wire leads and test this to that and this to that until you pinpoint which are which...
in the meantime ill try to find you a diagram... im bored
Anthony
2004 Tahoe LT (MA)
Westen MA
*Any updates to this?*
I just got an Escalade console (Clock area+ Cup holders +Clock) off eBay and looking to have the correct wiring to make ti work in my 2004 tahoe. Any input please?
denalianyone
denalianyone
NYBlackLade08
New York
I used the wiring diagram from alldata. Ill try and post the pic later tonight.
denalianyone
denalianyone
NYBlackLade08
New York
here ya go...crappy iphone pic
pin#1 battery positive
pin#2 ground
pin#3 Inst panel supply voltage
Anthony
2004 Tahoe LT (MA)
Westen MA
pin#2 ground
Thanks!
Also, Chistoso PM'ed me this info:
There are three wires on it, orange, black and grey.
The grey one is for the illumination
the black is ground
the orange is for constant 12v.
Great to have all this info in 1 place :Handshake:
JamesinAbilene
