How do you get these bulbs out?
Oklahoma
I can not fit my fingers in there. I took off the whole peice but that didnt help. Does anybody have suggestions on how to get these out?
jdpromo33
Proud Tahoe Owner
Bloomfield, New Jersey
Yes the metal shroud around the bulb just drops out.
But you have to use a thin knife or stanley blade to ease it out.
Mine came out very easily once you get a blade in there
RenaliSTL
St. Louis, MO
those were a ***** to put back in w/ LED bulb...mainly getting the clear lens back on flush & keeping the bulb connected. pro tip: disable all ur lights b4 install...i drained my battery doing that
jdpromo33
Proud Tahoe Owner
Not sure what you mean, mine went in fine and not sure how you would drain a battery from 2 small led's!
The bulb fits into a metal connector and shouldn't come out once installed, then you put the metal shroud over it then snap in the lens cover
It was a 30 second job
killer20072001
Oklahoma
Ok thanks John. I was gonna try but I figured I would ask before I go prying on stuff with a knife.
RenaliSTL
St. Louis, MO
cheap LED bulbs, they wouldn't go in with my fat ass thumbs + bulb was wider than shroud opening...had to put in the bulb w/ metal shroud already on it in one shot (couldn't see what i was doing). Bat died i think b/c im stupid and had the dome light switch all the way up or something. it was kinda haphazardly done...
dizhai
