Rear end sagging?
riviera rider
after installing my 3" body lift kit i can see that my drivers side is sitting roughly 1/2" to 3/4" lower than the pass. side. kind of annoying looking, i havent put in my new shocks on the rear yet, could that be the problem or is is the springs??
its just in the back that annoys me, my front is the same way but im going to mess with the keys and get the front aligned up, just trying to figure out the culpret for my rear end being lower on one side
bowtiefreak
No Quarter
Near Philly
springs sag over time. A 1" block or zero rate will bring it back up, mabe even a 2" block depending on the sag. The sag rom side to side is leafs and torsion bar sag. Give them a tiny crank back up to level from side to side
bowtiefreak
No Quarter
Near Philly
basically a lift block that also alows you to shift the axle forward or backward a little. Do a quick google search and they will pop right up
riviera rider
riviera rider
how hard is it to change the leaf springs yourself?? they're only like 180$ i seen might just do that if its not too hard
99COOP
Retired
Chicago, IL
The reason you get your lean is because like bowtiefreak said the springs wear over time. Also since you have a four door the gas tank sits on the drivers side adding that extra weight so it sits about 3/4 on an inch lower. Since i didnt replace the leafs w/ my lift kit i took out my spring pack and had a shop re-arch my spring. Needless to say i sat perfectly level and got rid of the annoyance for 18 bucks plus my time.
riviera rider
riviera rider
yes my pass side rear sits about almost an inch higher than the dr side rear, its verrrrrry annoying looking
what kind of shop can i bring that to to do that?
newmarketeod
It wont cure your sag, but to counteract any more sag you could swap the springs
fyremanpat
Fyremanpat
air bags wont cure sag???? I beg to differ. You put new springs in it will still sag under load. Bags COMPLETELY cure that.
GoodmanOX
how will replacing the leafs not fix the sag? have to use a helper spring too? speaking of helper springs, what's a good model for a 99 tahoe?
GoodmanOX
No, I was looking at replacement leafs on summit's site and there were several different choices for ride height i believe. Need to know which ones replace the factory.
