Interior Light Problem
Billy_ocean04
Michigan
hey got a problem. when i open my door, the dome light and door lights dont come on. sometimes they do and sometimes they dont. when im inside my truck and i turn the dome light knob on, the dome light and all the lights on the driver side come on but not the passenger side lights. do i have a short? i hope not. please help
josetizapan
Iowa
Ok do you have problems with your windshield wipers, stereo turning off and windows not wanting to work when your driving?
The reason im asking is thats how my 99 denali started with the the interior lights not wanting to work then couple months later my windshield wipers and stereo and windows only worked when they wanted to and it turn out to be my Body Control Module(BCM).
But i would first start by checking if youre headlight and dimmer switch is good.
Billy_ocean04
Billy_ocean04
Michigan
Well my wipers and radio work fine for now. Do I have to remove those two switches to check them?
josetizapan
Iowa
It's just one swith for both and i would just go to the local salvage yard and pick one up i got one for free when i got the trim bezel.
josetizapan
Iowa
One other thing that i forgot to ask is if the lights doesnt turn on with the other doors make sure the dome overide buttom is not pressd in and that the light bulds are not burn up i guess i should of started with ? first?
branndon_b
Lake Charles, LA
the dome override button makes the interior lights NOT come on when you open the doors. comes in handy if you're working on something that requires you to have the doors open for long periods of time. or if you need to sneak a pee somewhere and want to be stealthy. keep us posted sir.
992door
Greenville, NC
Do the lights come on when you open the passenger door by itself or the rear.
I know mine come on when they want when they want when i have the door open. Half of the time when i open my door no lights come on i am just to lazy to replace the sensor or whatever it is
Billy_ocean04
Billy_ocean04
Michigan
When I open each door individually it's still the same. Passenger door lights are still out. Even when I toggle my dimmer switch it's the same result
ZeroCool
I have the same issue! Posted another thread a few days ago
TigerEyz3
Slow and Steady
TN
If it's just the passenger doors (all others areas light up as expected), I'd make sure the bulbs in those doors are working (not burned out). If the bulbs are good, you've got a wiring trace ahead of you to make sure nothing is grounding out and that all connections are solid.
My Tahoe has door switch issues - as in the front door switches don't seem to be functioning properly (all bulbs light when the switch is triggered). The most used doors are the ones that typically have this problem. Just a heads up... BTW, my Tahoe has 250k miles on it, so it's seen a lot of door opening/closing cycles.
JamesinAbilene
