Instructions on dual battery Tray install 95 HOE
Goebz
Rural Ohio
I have the factory LH battery box but their instructions are not very descriptive. It shows it goes over top of the Evap Cannister but the Can is too high, the batt will not clear the hood. I can slide the can down about 2" in clamp but still need 4" for battery to clear hood.
HELP!
kaoticlife
Port St Lucie, Florida
HELP!
woah never mind this post was back in 2010.....delete delete delete
did you ever get your batt tray in? I dont know about 95 butmy 99 was a cinch, it goes above the windshield washer reservoir, do you have the storage box in there? if not should just have to punch out the plastic plug in the fender and it sits right in, run the nut up on the bolt that goes through the fender and your done.
WITCH1975
